Hey,
a quick question concerning your branch of Marlin. I need to change some lines of code, but still would like to use your handy configuration-tool. I tried downloading the whole firmware from github and the configuration.h from your site, but compilation with the Arduino 1.0 editor (even before I change anything) fails due to some errors like
In file included from /wiring_private.h:27,from WInterrupts.c:34:
c:/tpultimaker/arduino-1.0/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected identifier or '(' before 'double'
c:/tpultimaker/arduino-1.0/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected ')' before '>=' token
Do I need another compiler? Or would it be possible to download an uncompiled version of the firmware from your builder tool (that would be awesome ). If so which process would you recommend to compile and upload?
Second question: looking through the firmware the only possibility I found to set and/or read the temperature for two extruders is to activate the extruder in question with T0/T1 and to use M104/M105 each time. Is there another way?
Thanks and regards
tp-ulti
Daid 306
