1 minute ago, ultiarjan said:Just did a dual print, Cura 3.1 and Ultimaker3, including a prime tower. The print order is correct.
Are you sure? can you show a video?
I will get a video later today.
And this is an ultimaker 2 extend thats converted to dual.
I normally use simplify3d for my dual prints with only an ooze shield printed turn iut great. But the support in cura 3.1 is better then simplify3d. So try to use cura for a dual print.
Both nozzles will do the first prime. And first laryer is good. Once it gets to the second laryer,
It will do
T0 ooze shield, item, ooze shield
Then
T1 item, ooze shield, item.
So T1 isnt prime and the item has holes in it.
If i add a prime tower the same thing happens.
Item before prime tower on nozzle switch.
I will get a video in about an hour.
But i use the cura play button and i can see if doing just as said
ultiarjan 1,216
