UMO+ - Different Nozzle Size
lugarcia218
Posted · UMO+ - Different Nozzle Size
I recently got a bigger nozzle size for my UMO+ (0.8 mm) for some quick prints. I imagine that using different nozzle sizes is quite common.
How did you manage to adjust the nozzle size in Cura 2.7?
    In the top level menu: settings -> printer -> manage printers, select machine settings. At least from Cura 2.3 onwards you can change the nozzle diameter of your configuration. For easy selection you can create multiple machine instances with different nozzles sizes. Alternatively change the Line Width in the print setup, this also works.
    gr. Marco
