Posted (edited) · Error in Raise3D printer definition
I've discovered an error in the printer starting gcode for the Raise3D printers in Cura 3.1, which will result in consistent underextrusion. There is a spurious line of gcode that sets the first extruder to 94% Flow Rate (which will be visible in the Tune page on the printer).
To correct this, please go to manage Printers, Activate your Raise3D printer, and delete the following line from the Starting Gcode:
M221 T0 S94
Edited by eldrick
