Depending on the amount you need, you might also consider casting them. First design and print an original, or a mould, and then cast as much as you need. Or a combination of both 3D-printing and casting. When casting, you could use other materials too like gypsum or concrete, which can be a bit porous for water and air. Depending on the application, this might be an advantage (allows irrigation, or removal of excess water), or a disadvantage (might leak).
Casting is a very educative process too for kids and teenagers, most like it. (Search on Youtube for lots of good mould making and casting videos.)
If it is a prototype system anyway, you might try as much different materails as possible, 3D-printed and casted, to see which works best.
geert_2 558
