To make sure you're truly back to "zero" with the install, go to Help -> Show Configuration Folder. The folder containing all your personal settings for Cura will open. Close Cura and then remove everything in that folder, once that's done you can restart Cura again. This should have you back to factory defaults so to speak. This usually fixes weird issues.
IRobertI 520
