I'm not sure if you are right, but it also doesn't work e.g. on the top layer and there it should work I think
tinkergnome 926
8 hours ago, gorischek said:I enabled the options for hopping in Z direction. But for some prints the printer ignores this
Just to be sure:
If you want a "Z hop" on every travel move, take sure that "Combing Mode" is deactivated
(because an enabled "Combing Mode" suppresses most of the retractions).
just checked: "Combing mode" is disabled
kmanstudios 1,120
I could be wrong here, probably am, but I think Z-hop goes over parts and not infill.
I hope someone will confirm or correct this impression I have.
