Posted
(edited)
· Z height with permanent printing plates
Hi, ok I think your solution is to use a Z-offset command. Printing uses absolute positioning and the z-offset command changes the physical position where the 0 absolute position is located. I think you are asking to bring your bed a bit closer to the nozzle when you say "a bit higher" ?
You need to put your G92 z-offset command into your Start G-code. You will find your Start G-code in the printer settings. Go to Menu item Settings, then select Printer, then select Manage Printers. A list of printers will be displayed in a dialogue box, select your printer from the list displayed and then select the "Machine Settings" tab on the right-hand side.
You will then get a dialogue box showing details of your printer and on the left hand side a box called Start g-code. This is where you enter your command. You need to do your positioning in relative mode, i.e. relative to the z axis position when this command is processed. So
G91;set relative positioning
G92 Z+0.050 ;set z-offset to move bed closer to nozzle by 50 microns
G90 ;return to absolute positioning
This assumes you want the move to be 50 microns
Oh, if the dialogue box already has g-code in the Start gcode box then best if you post it here, before doing anything. Especially if it has G90,G91 or G92 codes
IMPORTANT: This is very important. I think G92 Z0.050 moves the bed away from the nozzle and G92 Z+0.050 moves the bed towards the nozzle, but I am not certain. I have only used the G92 command withabsolute positioning and the Reprap paper on commands I am looking at, does not comment on negative vs. positive positioning when using relative positioned commands.
Hopefully someone on the Forum can give a definitive answer.
Anyway I will advise you to test this.
I assume your gap between the bed and nozzle is 0.1mm and so I chose 0.050mm as being midway.
After the G90 command enter the command for an emergency stop - M112
This works with most firmwares but not Sprinter; I do not know what firmware you have.
Before running the g-code, slide a piece paper between the bed and the nozzle, you should feel some slight friction.
Run the gcode and check again; you should feel an increased friction; if you feel nothing then the codes are the wrong away around - the bed has moved away from the nozzle.
And finally change the 0.050 measurement to what you want.
Edited by yellowshark
On April 20 - April 23 we will host the Ultimaker Transformation Summit. Come talk to us via Live chat and get inspired by any of our relevant presentations!
yellowshark 152
G91 ;set relative positioning
