Adaptive print resolution?
peterswift
Posted · Adaptive print resolution?
been waiting for this feature for a long time.  Is it not quite easy to do a script that makes the print resolution adaptable depending on the angle or what ever. So the flatter the surface becomes the higher resolution becomes.  ( Just set a max and min resolution).
    Posted (edited) · Adaptive print resolution?
    Hello,
    I just installed cura 3.2 beta to try the new adaptative layers feature but I can't find it in the experimental setting (in setting visibility menu). Do you have any idea why ?
    I already try to uninstall, install again and search for ''ada'' in all the setting and nothing.
    thank you.
    Edited by toshi
        • 56 replies
        • 29 replies
