Yup, that's because it's very hard to implement. This is just a start to see how to move forward from here. With multiple models it's almost impossible as the layer heights are different per model then, which could cause a collision with the print head.
In short, this was the most I could do in ~4 weeks without having to rewrite the entire CuraEngine
kmanstudios 1,120
Just went in and set up a model that I made sure the file that created the void and the master solid file did not overlap. But, since the interior void file either had the modified settings for creating the void, or was inside the other model, it would not use adaptive slicing beyond the first layer that the void began.
