temperature not output correctly, always 210
mchahn
Posted · temperature not output correctly, always 210
Not matter what I put in the values on the right of the screen, in my profile, or material, my material_print_temperature is always 210.  The bed is output correctly.  I've enclosed a screen cap of my settings.
This is my initial gcode ...
;Sliced at: {day} {date} {time}
G21        ; metric values
G90        ; absolute positioning
M82        ; set extruder to absolute mode
M107                               ; start with the fan off
M104 S{material_print_temperature} ;Start heating extruder
M140 S{material_bed_temperature}   ;Start heating bed
G28                           ; Home all axes.
G29                           ; Auto-level the bed.
G0 X253 Y0 F9000              ; Move to the right of the bed.
M109 S{material_print_temperature} ;Wait for extruder to reach temp before proceeding
M190 S{material_bed_temperature} ;Wait for bed to reach temp before proceeding
G92 E0                      ; Zero the extruder.
G1 X253 Y151 E40 F700       ; Extrude a fat line of filament to prime and clean the nozzle.
G1 E-2 F500                 ; Retract extruder
G1 X126 F9000               ; Sweep to cut any strings.
This is the output ...
;FLAVOR:Marlin
;TIME:12440
;Filament used: 13.5601m
;Layer height: 0.2
;Generated with Cura_SteamEngine 3.1.0
M82 ; absolute extrusion mode
;Sliced at: Sun 28-01-2018 22:43:45
G21        ; metric values
M104 S210 ;Start heating extruder
M140 S50.0   ;Start heating bed
M109 S210 ;Wait for extruder to reach temp before proceeding
M190 S50.0 ;Wait for bed to reach temp before proceeding
    I have this same exact issue in Cura 3.1.0. No matter what values I put into all the extruder temp fields and yes I changed all of them, it still outputs 210 into Gcode, see below ( and yes bed was set at zero on purpose) It changes to the correct temp much later in the gcode. I do not understand what is going on
    M104 S210 ; set extruder temp
    M140 S0.0 ; set bed temp
    M190 S0.0 ; wait for bed temp
    M109 S210 ; wait for extruder temp
    This is a known bug in cura 3.1.0.  Fixed supposedly in older or newer versions.  Certainly in the 3.2 beta this should be fixed.  It doesn't affect Ultimaker printers so the bug wasn't caught I suppopse in QA.
    I have the same problem, time to try the Beta version then!
        • 1 reply
