Yes, I would not recommend to change the tension on the feeder. If it would show to be necessary, it is probably a band-aid for a different problem.
It looks like your print got interrupted quite abruptly, but it recovered after. I think it is not something you need to change in Cura, but you may have had the misfortune of some dirt in your nozzle / print core. Did you use Ultimaker ABS? The very cheapest of materials sometimes can have chunks of trash in them, which don't melt properly and can cause a clog. Like @Brulti says, perhaps clean your feeder to see if there is dirt in there that might got dragged up with some filament. Was the filament easy to retract through the bowden tube after the failed print? (if not, you might want to inspect the diameter, perhaps it was inconsistent and there was a thicker section in there).
I don't think it would benefit your print to disable retractions and I don't think it should be necessary. How big is it in total?
Brulti 176
I never had to change the tension, and I printed things with the whole array of UM materials for tests when I got my UM3E.
ABS should print as well than PLA or other with medium tension. As @SandervG said in another thread, there is no reason to change the tension in the feeder.
From the pictures and what you said, there was obviously a misfeed for some reason, since the filament was ground up, and it also looks like a missed layer as well. Have you checked the slicing for the bigger version in CURA using the layer view? There may have been a bug during slicing.
I'd suggest doing a thorough cleaning of the feeder, to remove all the dust from the ground up filament, and also of the bowden tubes, just to be on the safe side. Check your filament for any defect, is it UM filament or another brand? And look carefully at the model in layer view in CURA before trying another print, to make sure there is no slicing error or problem with the model.
As a side-note, I'm going to add another reason to be baffled by all the uses for 3d printing! A jig for slicing prostate glands prior to examination. Awesome! ^^
