21 minutes ago, nallath said:The profiles that it can select are also dependant on what the second extruder can print. For example; If the left extruder has 0.06, 0.1, 0.15, 0.2 and the right extruder supports 0.15 and 0.2, you can only select the 0.15 and 0.2
I assume that is what causing issues for you.
I think that might be my issue - I have breakaway in the right extruder. However, the restriction still shows up even if I don't try to print using that material.
nallath 1,125
