UM2 Built Plate not heating up
waitee
Posted · UM2 Built Plate not heating up
Have been running my UM2 for since 2014 with the usual maintenance and not having major problem.
Today suddenly there was a bad burnt smell and my print was in a mess of tangle wire.
Going through the maintenance menu found Built plate heater not working.
Have to check tomorrow to see what is wrong.
Anyone face this problem before?
    Yikes, I guess one of the wires had worked loose and was shorting.
    I had my wires come unsoldered from the buildplate itself. Difficult to solder because of so much metal, but it's been working for a couple of years since the repair.
     Yea it is because the connector is the spring loaded type and not screw on - before this happen was getting some very bad print with lifting from the built plate.
        • 30 replies
