Is it possible to edit/create .curaprofiles in a text editor?
carvedblock
Posted · Is it possible to edit/create .curaprofiles in a text editor?
I'm on Mac. I have tried Atom, Sublime Text, TextEdit...
If I make any change to an exported curaprofile, then the re-import fails.
I get "Errno 22, invalid argument"
Is there any special encoding or line ending or something that gets messed up?
Thanks for any pointers!
    Thanks. Very useful @nallath
    I can confirm that I can now modify the profiles!
    Howto modify a .curaprofile
    • Open the .curaprofile as a zip archive
    • modify the files
    • re-compress the files
    • ONE WAY: a bit convoluted way to do this with no 3rd party software
      • rename the profile to `profile.zip` instead of `profile.curaprofile`
      • extract the files
      • edit them
      • re-compress into a new .zip archive
      • rename to .curaprofile again.
      • done
    • ANOTHER WAY: simpler, but you need to install the open source and cross platform B1 Free Archiver
      • Open the .curaprofile archive with B1 (no renaming necessary)
      • Double click on the file you wanna edit
      • it will open in your default text editor
      • make you changes and save
      • the program will ask you if you want to save the changes
      • done. (B1 will re-compress the archive in the background)
    • 4 years later...
    You can use this list, if you remove the {} around the setting names, and ignore the "Application-defined patterns":
    http://files.fieldofview.com/cura/Replacement_Patterns.html
    This page is actually generated from this file (which is part of Cura):
    https://github.com/Ultimaker/Cura/blob/master/resources/definitions/fdmprinter.def.json
