If you have a v2 hot end, there are openings in the housing which allow you to guide the bowdentube, so you can push it fully down in the teflon insulator. I always do that, pull it up again to insert the horse shoe, and then push it down again so it is always under pressure, and fully down. Doing a complete rebuild is probably also effective, but this is a bit faster i think.
ian 32
good advice never goes out of fashion !
thanks a lot.
Ian :-)
