cura 2.1.2 no image when open stl file
shelby5041
Posted · cura 2.1.2 no image when open stl file
hi i am brand new to 3d printing
i downloaded cura 2.1.2
i have windows vista 32bit laptop
amd athlon 64
ati radeon
when i open a stl file in cura nothing shows up in the image workspace........no grid....no part.....just white space
it goes through slicing process and then says save file but there is no object in the workspace....so i cant see what my  part is suppose to look like
what am i doing wrong?
    We don't really support 2.1.2 (or anything of similar age) anymore. I'm afraid your only fix is to upgrade your laptop/desktop to a 64 bit machine and download the latest version of Cura (3.2).
    Hi
    i appreciate your input, however im not going to spend hundreds of dollars just to be able to use a free program lol
    and fyi version 2.1.2 was designed for 32 bit windows so it should work with 32 bit windows correct?
    guess what my fix was?....very simple...i downloaded slicer....and guess what?.....it worked
    thank you
    is legacy cura free and where avail?
    You can find it on this page: https://ultimaker.com/en/products/cura-software/list. 15.04.6 is the latest legacy version. We don't support it anymore so don't expect any help if it doesn't work for you.
    ok...in cura how do i adjust heat bed temp after certain layer? or first layer?
    slicer can do it...can cura do it?
    hi again it seems that the cura legacy version download is no longer avail on ultimaker website?
    where can i download version 15.4 so i can use with windows xp
    thank you
