yellowshark 153
As @kmanstudios says if we can see your settings we can help more. One setting that significantly affects what you see is the Layer Height which gives you the resolution of the print. 0.3 is normally the thickest/lowest resolution and will show the lines more. If you drop to 0.2 the lines will show less and if you drop to 0.15 or 0.1, even more so. Personally I never drop below 0.1 unless I have a "horizontal" surface that is curved in which case I may drop to 0.05, but I will do a test first to see if it is worth it.
kmanstudios 1,120
Welcome to the forums![:) :)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
Post some pics to show what is happening, tell us what printer and screenshots of the settings used would be good.
