Printing with PVA
markwain
Posted (edited) · Printing with PVA
Hi there!
So ... I am new to printing with PVA. (I want to use it as support material).
Is it best to use some adhesive while printing large parts with PLA+PVA. (My case is - most of the print bottom layers will be support material, which is PVA).
Appreciate any help :)
Edited by markwain
    Posted · Printing with PVA
    Not at all.  Just use a 60° bed temp (default for PLA / PVA printing).  Here's some screen shots of a 7.5" tall part, bottle, that is almost entirely PVA on the build plate.  About a 6 hour build.
    Bottom Layer
    4th Layer
    8th Layer Showing Support Roof
    12th Layer Showing Bottom of Part over Support Roof
    Final Part
    This part is hollow (0% In Fill).  Start out using the default settings and adjust accordingly.
    Hope this gets you started off on the right path.
    I find that PVA adheres very well to the glass bed.  About the same a PLA and much better than ABS.  Without knowing what it is you are attempting to print, I have no idea whether or not you may need a brim.  As you can see, the part I have posted uses no brim at all.  Just two lines of Skirt 3mm away from the part to assure a good prime of the extruder.
