I'm not sure what you mean. When the bed gets up to temperature they flash about 20 to 50 times per second. Most people don't notice this. Is this what you mean or even when you first turned it on? If it's flashing when you first turn it on (but not the bed heater is off) then it's probably a bad wire or bad LED strip. The wiring can get caught in the belt and pulley system.
The leds blink all the time, until I shut off the printer. I can even print a piece and leds are happily blinkg all the way. It affects only the left vertical side. The top and right leds do not blink. Is it easy to replace these led strips ?
gr5 2,230
