UM3 replacement belts
Posted · UM3 replacement belts
If you just want belts and sliding blocks and not the whole maintenance kit, those are available here: https://fbrc8.com/collections/ultimaker-3-spare-parts/products/sliding-block-set-um3-extended
But the shipping might be a little high if they need to go to Germany. Alternately, your reseller in Germany can probably order belts in on request if they don't carry them.
