Are you using Cura 13.06.X? As it has changed the way walls are filled.
One setting you can try is to set the skin thickness to 100mm. I believe it will fill with continuous passes only. Just try it and see what the gcode view looks like.
Also you can reduce those little blobs by lowering the temperature (see first photo):
gr5 2,004
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
