Again, I'm having the same issue :/
I did not find another way to solve the isseue than repeating this routine:
Quote
Now I copied the User/AppDate/Local and Roaming folder content from one of the PCs with a working Cura profile to the affected PC. Now it works againg.
trisn 0
Edit:
But - how is this going to be solved If there would be no working Cura installation to copy the cfg from?
Thank you.
