It's hard coded at 60 right now. But if you hack Cura/util/sliceEngine.py this is where the actual engine gets called. Search for 'supportAngle' there you'll find the hard coded 60.
Thanks, Daid. I'll try it!
gr5 2,230
I can do about 80 degrees from horizontal. Are you sure you can't do 60?
Having said that, I should also mention that Daid said the support feature needs a lot of work.
