Revision 4 Laser Cut Panels
makrmark
  • 3 weeks later...
Posted · Revision 4 Laser Cut Panels
I have laser-cut some parts from the files downloaded from this link: http://www.thingiverse.com/thing:13571 and found out that the teflon tube could not be inserted into the front right opening of Part 8B (from the RIGHT Panel) when assembling the extruder head. The opening has a smaller diameter than the teflon tube.
    • 3 weeks later...
    • 2 weeks later...
    How thick is the material used for the Ultimaker?
    I have access to a CNC machine and I have to tell you, it is very tempting to cut these panels in aluminum. Polished, it would look pretty amazing =)
    Well let me add to that ...finding millimeter sized aluminum is a challenge since everything here is Imperial.
    My concern is that the close-equivalents wouldn't work well.
