Thanks ahoeben - OS is windows 10. I don't think 3.2.1 was running at the time - I will double check.
No other apps. I also seem to recall first installing 3.3.0 on the laptop connected to the printer and not seeing any CR10 profiles listed at all ? If I remember correctly, I then installed 3.2.1 , and added the cr10 profile in 3.2.1 .
The next time I tried 3.3.0 the CR10s were listed - is it possible that 3.3.0 was accessing the 3.2.1 printer profiles and that may have caused the issue ?
ahoeben 1,968
Did you perhaps leave Cura 3.2.1 running in the background, or is there another application that could be using the serial port?
What OS are you using?
