excuse me can you help me
Posted · excuse me can you help me
I come form china,I want to make double nozzle .like5adc777da76ca_3A67XVBUVZHVAHW0W.thumb.png.7134ec99ff786558ab45e9e98397c0be.png
Do you have an opening tutorial?  please help .I searched Google for days, but I couldn't find what I wanted
    Dual nozzle in the same head doesn't work so well unless the idle nozzle can be moved up.  I strongly suggest you read about the mark2 which works for UMO or UM2.
    31 minutes ago, gr5 said:
    除非可以向上移动闲置喷嘴,否则同一喷头中的双喷嘴不能很好地工作。我强烈建议你阅读关于适用于UMO或UM2的mark2。
    41 / 5000
    Thank you, but my machine is DIY, with the motherboard is not um2 special use, with rams 1.4
    • 2 months later...
