Posted · Build plate leveling: z level changes
I just assembled my new Ultimaker Original +.
Today I installed Cura and tried to perform the Build plate leveling.
There I get a problem: the head goes to the front left position, I calibrate the position with a piece of paper. The display of the controller tells me that the z position is 3 mm here.
So far so good.
But then the head goes to the front right position and changes the z position to 6 mm. Therefore I can`t adjust the level at this position because the plate is too low :-(
I can`t reach the distance 0.1 mm with the spring.
I hope someone can help me
Kind regards,
Vinzenz
          • Heart
        • 4 replies
