Cura connect and authentication
JPFrancoia
Posted · Cura connect and authentication
I work at a university as a researcher. We recently purchased an ultimaker 3. I just installed it and upgraded it to the last firmware.
After fighting a bit, I can now access it remotely (with a browser or with Cura).
However, when I connect to it (whatever the way), there is not a single time where I have to authenticate myself. No password is required to access the printer.
I would like to restrict the access to this printer with a password. It's on the university network and anyone knowing the IP of this printer could access it, and maybe break it.
Is there any way to set up  a password ?
Cheers
    Btw, from your comments I see that you're a University user? Would you mind reaching out to me on c.terbeke@ultimaker.com? We're interested to talk to use cases like Universities to see how we can better cater to your environments.
    Thanks!
    Just now, JPFrancoia said:
    do you have a RSS feed ?
    We don't. We post update blogs on the Ultimaker website.
