Thanks much for the response. Setting all speeds to the same made no difference (in this case 20mm). Also enabled z-hop but made no difference on the scaring. Do you think layer height is an issue....printing as .15 atm.
It looks like the nozzle makes a 'dry' pass over the problematic area's as if its trying to smooth the surface out. Is this possible?
gr5 2,210
top image I think is what you mean by "left unit" and bottom image is the "right unit".
In cura type "speed" into the search box and it will show *all* speeds, not just ones that are normally visible. Make all the speeds the same. I think the cororing is because it is printing different speeds for infill versus shell.
