10 hours ago, ahoeben said:See the Printers pane of the preferences, and press "Machine Settings". You can enter the bed dimensions there.
If Cura does not detect your printer, there is not much you can do about it at this point.
That layer is called a "brim". It helps making sure your print sticks to the bed. If you want to try printing without the brim, you can turn of the option to print it in Cura. See the Build Plate Adhesion option.
Thank you so much.
ahoeben 1,800
