6 hours ago, nallath said:you assume that quality has no interaction with material
I had an example that spoke to this:
On 5/10/2018 at 1:18 PM, kindaNobody said:You've selected two profiles (ABS + Fine Detail) but your ABS Material profile calls out a print-speed, and you would rather use the speed defined in Fine-Detail.
...and then of course if neither was exactly what you wanted, you've still got the option to enter a third number. This might be somewhere in between the two saved settings and that's really useful because you can actually see what other profiles have saved (not just the currently loaded profile has) to base your new value on. The real trick to making this approach fantastic would be a UI to choose which profile new values should be saved into - preferably right there in the list of settings, not in another dialogue that pops up.
6 hours ago, nallath said:Originally we started of with the exact approach you suggest, but we quickly had to diverge from that strategy as it simply wasn't enough.
You're saying that saving the entire list of settings wholesale without a way to build from multiple profiles (beyond just typing the differences in by hand) is more powerful than allowing users to add them together? I don't see how; you can still do everything the current implementation can with the additive approach plus bring in other profiles and reconcile the differences.
nallath 1,119
You're both right and wrong ?
The problem here is that you assume that quality has no interaction with material, but this is (unfortunately) not the case. The ABS normal profile is different from the PLA normal profile. It's actually so different that merely "stacking" quality + material together does not fully describe what needs to be done. Originally we started of with the exact approach you suggest, but we quickly had to diverge from that strategy as it simply wasn't enough.
