I agree, there shouldbe an option to turn off this check in Cura. Or at least pupup a dialog with a warning (right after ju press print) with a Cancel/Ok button. Now we have to click on the printjob, expand the mesasge and press overide... and then confirm again...
ultiarjan 1,215
Think of a scenario where you have a bunch of printers in a farm, loaded with multiple material types. Setting the material on the printer will make sure Cura Connect knows which machine can be used for which job. So it's actually not to anoy users of non-ultimaker material, but to make sure you can also use non ultimaker material in a print farm.
I always get annoyed when I get the warning if a different color of PLA is loaded. I think the best way around the issue is some improvements in the Cura Connect GUI so the override is easier and more intuitive.
