You can't. Profile is shared between both extruders. You're either in custom or recommended.
However, not every setting is shared between both extruders, so changing settings on extruder 1 will not always affect extruder 2 which should then default to the default settings for the selected material.
What settings did you change and did you change them only for extruder 1 or also for extruder 2?
Brulti 177
