46 minutes ago, gr5 said:Three thoughts:
1) retraction. Check the print in layer view and try to find these spots and see what happens there and in particular if there are any light blue lines in these spots which are retraction moves - you might need to play with the retraction distance. Retracting too much or not enough can cause spots just like these.
2) speed. Try printing at half speed - it's amazing how much better the quality can be.
3) slicer. Try cura 15.04. I'm not sure but it seems like some of these blemishes don't happen in cura 15.04. I don't understand why as it's the same slicer engine but some setting or something may have changed. Many people (many!) have had better luck with cura 15.04. However I have had excellent results with cura 3.X so I don't know what's going on.
What kind of printer is this?
It's a Anet A8, I'm slicing with Cura 3.3.1. I was playing around with the slicer's options when I found out about coasting. It turns out that when I enable this experimental feature, it shows in the preview the exact same scars that are found in the print. I'm really confused about it. For example, the wing picture that I attached earlier was sliced without coasting being enabled; though it was printed with the scars that shows Cura when I turn coasting on. With this feature off, it just shows the smooth surface it should be printing instead.
Any ideas about this?
gr5 2,243
Three thoughts:
