do you have to adjust the temp too or is that pre defined by the material PLA Ultimaker?
I was not able to find anything to set the temp to 230 C.
Also I know it is big ?. This is for rough prototyping only
i have the moarstruder for a taz 6 and the s-Erde for inclass rough prototyping is great
we have 4 um2+ in my class room so we might consider to use the 0.8 mainly now
since often model studies is what students print
we have one um3 for finer prints
Edited by cekuhnen
gr5 2,331
Well UM printers can print a volume of about 5 to 8 cubic mm/sec through a 0.4mm nozzle at 230C and the 0.8 has 4X the area so you should be able to push 20-30 mm^3/sec.
So for example if you want to approach those speeds I would do:
line width=0.8
layer height = 0.5mm (so thick!)
print speed=50 to 75mm/sec
If you multiply line width, layer height, print speed you get the volume rate of extrusion. 0.8 X 0.5 X 50 = 20mm^3/sec
