Posted
· gaps appear as print gets higher/bed gets lower
After much deliberation and noticing that the PLA was coming out of the nozzle at a slight angle I decided there was a partial clog right at the tip of the nozzle which I had not been able to remove in my previous attempt to clear the hot end of any blockages. I heated the hot end up, removed the nozzle(apparently you should not try to remove the nozzle cold as it can shear off) and cleaned it out by using a lighter to completely burn out anything in the nozzle, there was a little smoke which leads me to believe there may have been a tiny bit of plywood or something flammable in there. I washed the nozzle and removed the soot with some wire wool (cleaning again and blowing out any particles).
HURRAY ! the ultimaker is now back to the quality I'm used to. Thanks everyone for their input, I hope this helps someone else.
greens83 5
