Cannot select some submenus of Cura
liuyifan494
Posted (edited) · Cannot select some submenus of Cura
This happens in the latest version and beta version of Cura under the environment of win10 64 bit operating system
2018-06-11_233808.jpg.26c4ccd4eb5039ebb0e2e7ce393edf07.jpg2018-06-11_233829.jpg.b1b746be3b5babc557f17d5fba78620d.jpg
2018-06-11_233840.jpg.60b070b1b7432b7a541c537f8c95646c.jpg2018-06-11_233858.thumb.jpg.8ed22177127a0a06ea4fa4e3b5c2cd47.jpg
Under normal circumstances,the  submenus will appear blue background when the mouse pointer pointing to it and can be click.
Edited by liuyifan494
    Posted · Cannot select some submenus of Cura
    As a workaround, try using the cursor-keys to navigate those menus. Doesn't make it less of a bug, but it might let you use the menu items.
    Thank you very much, this method does work!
