This is baffling! I removed every aspect of Cura, downloaded and installed again, and upon startup, even the user agreement loads as a blank white screen.
I just downloaded it at work, and installed from scratch. It is the same computer (Microsoft Surface), however the software IS displayed on different monitors. It seems to have something to do with the displays itself. I guess I need to fiddle with the display settings on the monitor at home.
Thanks for the reply!
-Matt
- 1 year later...
Oh wow! This has plagued me for ages right up to and including 4.5.0. I use Cura on a very old laptop running Mint 19.3 Xfce Edition. So every now and then when i wake the laptop, load Cura 4.x.x it would sometimes white screen at startup. The only way for me to fix was a wipe of the OS and reinstall. Renaming the qtshadercache to qtshadercache.org fixed this problem. Thanks so much!
- 3 weeks later...
gr5 1,872
I've never seen this but you should know that for a proper uninstall you also want to delete everything in the cura user folder. On a PC I believe that is in the folder %appdata%/cura/
Delete everything in there and then start cura up again and it will be like a fresh install of cura.
