Thank you, @nallath! I went to the /printers URL and detached the printer from the group (no idea why it's been part of a group to begin with), then I confirmed on UM5 touchscreen to allow Cura Connect access and now the web UI is displaying printer details & the cam live stream. However, the Cura desktop app simply crashes when I attempt to re-add the printer via IP address (after typing in the address). The crash log is attached and a brief glance seems to hint at some proxy query...
nallath 844
Try to manually add the printer by IP (press add and use 192.181.1.194).
If that doesn't work; verify that if you go to 192.181.1.194/printers that you get a screen showing the one printer.
