Hi
Im aware of that, it popped out after I opened up the housing. I wish that was the root cause since I did put it back upon reassembly. Now if the level indication goes up, that’s less tension? For some reason I’m having trouble with Ultimaker filament. The previous types I had in there printed very well.
tinkergnome 927
Since you mentioned the guide from fbrc8.com:
The pictures there are very good - the important steps to get the tension right are:
on your picture the screw-head is outside of the case - which is wrong and can cause grinding...?.
