Posted · Issue with PVA
Hi Everyone,
As shown on this image, this print with PVA (transparent) and Nylon (black) partially failed:
The PVA support is not building up correctly and I don’t know why.
I use an ultimaker 3 Extended with an enclosure to get minimal wrapping and stable printing temperature.
And I use the PolyBox from polymaker to keep the Nylon and the PVA dry (at less than 10% humidity)
I use an adhesion sheets so the PVA and Nylon stick very well to the plate at 65ºC
The print setting for this ultimaker PVA are: 215 ºC with a speed of 35 mm/s, support pattern triangles, support density 80% (i.e the default settings).
I have tried many things to avoid this problem:
+ select ‘connect support lines’
+ set the support density to 100%
+ use a brand-new roll of PVA
+ place the PVA directly on the back of ultimaker 3 (i.e without the PolyBox) to reduce the friction
+ cleaner the feeders in case it causes under extrusion.
However this problem with the PVA still occurs almost systematically.
If someone one as suggestion to fix this problem with the PVA support, it would be greatly appreciated.
Thank you
Charles
          • Heart
        • 4 replies
