ah ok, thanks. is it worth enabling ?
is there some sort of limitation in Cura which prevents it having pickable supports like the other slicers ?, seems odd Cura leads (for me anyway) in all areas apart from supports, which seem to have been a bit 'hacked' to get something which still isn't that great
ahoeben 1,968
Try it, and you'll know.
It is pretty much the same as the Support Blocker, in that it lets you add "cubes" to the model. But these cubes are printed as support. It shares all the quirks of placing Support Blocker cubes. On small parts it is also easy to end up with support material on top of the model (where it will not do any good).
