Thanks for the project file, I have verified the problem and will try and find out what's going wrong and come up with a fix.
Hello @smartavionics,
Thanks for your prontitude on solving this issue.
This model is for a school project and I needed to print some of them till the end of this week.
Is there any chance you could send me the Cura executable with your changes?
Thanks
Edited by amagroHi @amgro. I can only build Cura for use on Linux, I don't have any Windows computers or Macs here. So I can offer you a Linux archive (just unpack and run the included script). Let me know if you want that. I attach the gcode for your current model. Please note that combing may not give you the best quality results with this model because in the honeycomb region the walls are very narrow and so the nozzle will be right on the edge of the walls in some places. Maybe in the future Cura will comb over thin walls better than it does now. It is still under development (like all of Cura, actually).
Thanks again @smartavionics,
I will print the gcode that you send me.
So if you can, please send me the Linux archive with your Cura changes.
You can find my Linux archives at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
Just unpack somewhere and run cura/bin/cura.sh
Sorry they are so big, I haven't succeeded in creating an appimage, these are just copies of my installation tree which has lots of files that you don't actually need. Good luck!
I'm having some issues opening the Cura.sh file, this are the erros:
_________________________________________________________________________________________________________________
beei@beei-VirtualBox:~$ cd Desktop/cura/bin/
beei@beei-VirtualBox:~/Desktop/cura/bin$ ./cura.sh
Error in sys.excepthook:
Traceback (most recent call last):
File "/home/beei/Desktop/cura/lib/python3.5/site-packages/numpy/core/__init__.py", line 16, in <module>
from . import multiarray
ImportError: libgfortran.so.3: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 665, in exec_module
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/home/beei/Desktop/cura/lib/python3/dist-packages/cura/CrashHandler.py", line 21, in <module>
from UM.Application import Application
File "/home/beei/Desktop/cura/lib/python3/dist-packages/UM/Application.py", line 9, in <module>
from UM.Controller import Controller
File "/home/beei/Desktop/cura/lib/python3/dist-packages/UM/Controller.py", line 3, in <module>
from UM.Scene.Scene import Scene
File "/home/beei/Desktop/cura/lib/python3/dist-packages/UM/Scene/Scene.py", line 13, in <module>
from UM.Mesh.ReadMeshJob import ReadMeshJob # To reload a mesh when its file was changed.
File "/home/beei/Desktop/cura/lib/python3/dist-packages/UM/Mesh/ReadMeshJob.py", line 5, in <module>
from UM.Math.Vector import Vector
File "/home/beei/Desktop/cura/lib/python3/dist-packages/UM/Math/Vector.py", line 4, in <module>
import numpy
File "/home/beei/Desktop/cura/lib/python3.5/site-packages/numpy/__init__.py", line 142, in <module>
from . import add_newdocs
File "/home/beei/Desktop/cura/lib/python3.5/site-packages/numpy/add_newdocs.py", line 13, in <module>
from numpy.lib import add_newdoc
File "/home/beei/Desktop/cura/lib/python3.5/site-packages/numpy/lib/__init__.py", line 8, in <module>
from .type_check import *
File "/home/beei/Desktop/cura/lib/python3.5/site-packages/numpy/lib/type_check.py", line 11, in <module>
import numpy.core.numeric as _nx
File "/home/beei/Desktop/cura/lib/python3.5/site-packages/numpy/core/__init__.py", line 26, in <module>
raise ImportError(msg)
ImportError:
Importing the multiarray numpy extension module failed. Most
likely you are trying to import a failed build of numpy.
If you're working with a numpy git repo, try `git clean -xdf` (removes all
files not under version control). Otherwise reinstall numpy.
Original error was: libgfortran.so.3: cannot open shared object file: No such file or directory
Original exception was:
File "/home/beei/Desktop/cura/bin/cura", line 134, in <module>
from cura.CuraApplication import CuraApplication
File "/home/beei/Desktop/cura/lib/python3/dist-packages/cura/CuraApplication.py", line 10, in <module>
import numpy
ImportError:
_____________________________________________________________________________________________________________________
Since I don't have enough knowledge to solve this error, could you please generate another gcode but now for a different printer?
I send you the Cura project with the stl and the 3D printer.
marcador_1.0.curaproject.3mf.zip
Thank you very much.
Hi @amagro, I attach the gcode. This was sliced with combing mode "no skin" and "avoid printed parts when travelling" turned off. I haven't printed it but the layer view looks OK.
As for the gfortran error above, it looks like you need to install the fortran runtime libraries so do "sudo apt-get install gfortran" and it should download and install what you need.
If you get the Linux version working, I will post another archive as I have done some more work on the combing.
Hello @smartavionics.
With friends help I finally had the Cura with you modifications working on Linux.
If you like you could share your Cura archives with your last "Combing" work.
Thanks
Hi, @amagro, I will post another archive later this morning.
Hello @amagro, sorry for the delay, new archive available now. I have been seeing some crashes when starting cura so maybe there's a problem with the current master branch? Anyway, once up and running it seems to work OK.
burtoogle 506
Hi @amagro, please attach the project file, without that it's not easy to investigate the issue. Thanks.
