One cannot edit a compiled firmware image in an useful way.
What are you trying to achieve?
If you're familiar with C you can edit the source files from @amedee or Ultimaker and compile it afterwards.
That's more or less the same as Option 1 - that's the only working way i know... (besides of Option 4... ?)
I suppose what im trying to achieve is a firmware with the same feature set I currently have while having the ability to add sensors or just simply continue on without starting over from scratch. It seems however that is exactly what needs to happen.
I can start with the Armedee or Ultimaker base firmware and modify from there. I simply need to get over the learning curve of Marlin in general. Can anyone recommend a good intro source to understanding marlin's layout and definitions other than the Wiki and git?
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
tinkergnome 926
Gencab 19
