Process for empty filament - filament runout - on s5
Posted
· Process for empty filament - filament runout - on s5
Yes, just go to the configuration overview screen (second icon on the left) and tap onto the material in question. Then select 'change'. The swap routine makes sure you will continue on the spot in the gcode but it might result in a plastic spot on the print.
1
Dim3nsioneer 558
