How to Change Layer height
dovk179
Posted · How to Change Layer height
hi, in the course of my  work I found out that I can reduce time and material If I use the option to change the slicing height for a short distance (Z), and then return the original quality definition. for example, start with original definition of .2mm  for 15mm , then change it to .06 for 2mm and back again
Thanks  a lot
Dov
