If you just upgrade from "the real UM2" to the UM2+, without all the changes needed, you might have a reveres feeder as a result (plus feeding much to fast).
The thing is; an upgrade to UM2+, also ask for a new feeder installation. Yes, you have to change the whole feeder unit into a new one that is rotating the other direction. There is also a different speed for the feeder as this also will feed very much to fast(to much feed)..
You need to change the feeder unit with the one needed for this software change, or you have to change the number of feeding steps and the direction of feeder back to revert back to standard UM2 settings.
It's fixed now thanks for your suggestion. I spoke to tech support on the phone Cura 3.4.1. has a bug with updating firmware downgrading to 3.4.0 and re-flashing cures the issue.
Many Thanks
Brian
Torgeir 264
Hi undertherain,
Thanks
Regards
Torgeir.
