@DF-Werkzeugservice I think you are right. I have narrowed it down with 99.9% certainty to the printcore itself. I think it's partly blocked in a permanent way because I've cleaned it many times but the result always stays the same. Alternatively it may be a temperature issue whereby somehow the print core slowly cools down as it prints because of a temp sensor issue. Now that I use another print core things work fine. Maybe I can give breakaway another try since I always used this printcore for that, and from day 1 it was a bit of a disaster.
DF-Werkzeugservice 9
This looks like underextrusion. Make sure to clean your printcore often, maybe it's also worn out or "unfixable" partly clogged after that time and you need a new one.
For me the UM ABS always used to work fine with standard settings. When I use Formfutura ABS, I had to go down with the printing speed, otherwise it always used to look like your pictures when making long prints.
I figured out to reach higher speeds with Formfutura ABS with the Matchless Race nozzles by 3D Solex. With that setup (of course with some nozzle replacing), I'm printing about 3 kg Formfutura EasyFil ABS each week for the last 1.5 years on my UM3E with an success rate of maybe 80 - 85%.
