On 9/5/2018 at 8:35 PM, mersault said:Is this for calibration? Like the printer settings are first set globally and then when it's time to print with the extruder the "-s" settings passed to the extruder overrides the global settings set.
2
It's not for calibration. Some settings can be set globally *and* per extruder. Infill density can be set globally and per extruder. This means that if the extruder does not provide a value, it uses the global value. If it does provide a value, that one is used instead.
1
nallath 1,080
Because certain settings are set per extruder. If you have two extruders, you need to set it twice.
Yep, should be the same.
This has to do with the first question again (at least the -e<extruder_nr> does). If you give a setting without telling the engine on what extruder it needs to be applied, it will use it as a global setting (Layer height is a setting that should only be set globally, since both extruders must use the same value). If you want to change a setting for a certain extruder, you can use -e0 -s setting_to_change="foo" to do this.
One at a time printing is even more complicated. When printing multiple objects, it's possible for certain objects to have a subset of settings changed.
mersault 0
Thanks for the response. My printer is only ever using one extruder for the print. From looking at the "-s" settings in cura.log I can only surmise that it first sets all the settings globally and then after the "-g -e0" starts setting "-s" settings for the actual print. Is this for calibration? Like the printer settings are first set globally and then when it's time to print with the extruder the "-s" settings passed to the extruder overrides the global settings set.
